Oil Leak
Old Jan 25, 2009 | 05:50 PM
playername's Avatar
playername
Default Oil Leak
Hey guys,
I ususally just hang out in the background and read all the info, and end up spending money on mods. but now i have a problem so ill see if you guys can give me some ideas. Tonight i went out to take the trash out....wonderful when its 10 degrees out. I noticed a small oil spot under my truck. I got under it and looked and the front crossmember has some oil on it and the side of the oil filter looks like it got sprayed with oil. I just had the truck inspected 2 weeks ago and i havent seen any oil on the snow on the driveway. Could the filter have worked its way loose on a super cold morning? Any ideas?
Thanks,
Les
BTW i have an 04 qc with the 4.7
Old Jan 25, 2009 | 06:06 PM
SeMiGoD's Avatar
SeMiGoD
Simple enough way to check, buy a new filter and slap it on. Spray some cleaner to remove the residual oil and see what happens.
Old Jan 26, 2009 | 01:53 PM
playername's Avatar
playername
well looks like its worse than i thought. it looks like the front crank seal is leaking. any suggestions? anyone else had this happen?
