Fuel?Water
Old Jan 30, 2009 | 07:58 AM
blackram1500's Avatar
blackram1500
Cool Fuel?Water
First I am new here and I own 2005 Dodge Ram 1500 with 5.7 hemi, I will post my pics soon. I have heard that you need to drain water from the fuel system and this what I read so is it true? (Filtration and separation of water from the fuel is important for trouble-free operation and long life of the fuel system. Regular maintenance, including draining moisture from the fuel/water separator filter is essential to keep water out of the fuel pump. To remove the collected water, unscrew the drain at the bottom of the Water-In-Filter (WIF) assembly located at the bottom of the filter separator)
SO WHERE IS IT LOCATED ON THE TRUCK AND HOW OFTEN DO I DRAIN IT???
Old Jan 30, 2009 | 08:03 AM
Redone4x4's Avatar
Redone4x4
sounds like instructions for diesels. diesels usually have a drain on the bottom of the fuel/water seperator that you unscrew.
Old Jan 30, 2009 | 08:10 AM
blackram1500
Cool Grat to know...
Thanks for the reply, Since I only got the truck 6 months ago and still learning things about it before I do my upgrading.
