3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
they are all the same within 200-250 cfm which not a big enough difference to argue over. The best CAI was the Ramhammer hands down but im pretty sure its not made any more as it was only a one man operation making it. Other than that, pick one....
Agreed. The Ramhammer was the best but as far as I know they are not being made anymore. However, there is a new version that is either already out or being released soon that is supposed to be even better, but pricey.
Here is my "homebrew" - some PVC and a real K&N filter, but basically a free-flowing set up.....
Thanks for the info. I think for now I might just get a intake tube to use with the K&N drop-in filter that I already have. I like the "home brew", how much did that run you and do you have a list of parts that you used.
I have read, via the internet, that adding a CAI might/could give you a "check engine" light. Has anyone had any problems with adding a CAI and getting a CEL. By making your own CAI did you get a CEL?
I haven't had any problems with mine. I got the spectre which has an aluminum tube and oiled filter like k&n, there is a cheaper version called Kool Vue if you want to look into it.
Probably because the mass airflow sensor (or whatever the rams have for air sensing) gets covered with oil over time from filters like K&N and in addition, most people oil their filters way too much. Been down that road my self
The only way I can see a light coming on is if the IAT sensor(intake air temp) isn't installed correctly. It would be hard to screw it up but I don't put anything past anyone
