removing a sheared bolt?
Old Feb 11, 2009 | 11:14 PM
mdram43's Avatar
mdram43
Default removing a sheared bolt?
so i have a bolt that sheared completly off. no extra bit sticking out at all. i saw a commercial not too long ago for a bit that was for this exact problem but never ordered it. anyone know the product, or a similar one to remove it? or just how to remove it period? thanks
Old Feb 11, 2009 | 11:59 PM
Thatonekidw/theHEMI's Avatar
Thatonekidw/theHEMI
buy a small reverse bit drill into it and then back it out
your local hardware store should be able to hook you up
Old Feb 12, 2009 | 12:15 AM
traker1001's Avatar
traker1001
I know what your talking about, they sell them at any hardware store. I use them all the time and they work very well. One thing though. Pray the bolt with penetrating lube and let it sit for a while before you use the drill. Makes things come out alot smoother.
Old Feb 12, 2009 | 12:25 AM
Rojhan's Avatar
Rojhan
Where is the bolt? I got an education a few years ago; I sheared one of the manifold bolts to the exhaust. It broke at an angle. I couldn't drill it. Couldn't get a grip with vice grips. Couldn't get a grip with a broken-bolt-removal-tool.
I went to a muffler shop and they lit up a torch to melt the bolt out while the cast-iron manifold just laughed at the heat.
Old Feb 12, 2009 | 12:28 AM
Hoss356's Avatar
Hoss356
You're thinking of the grabbit:
http://www.acehardware.com/product/i...ductId=2967894
but a quick search and you'll find all kinds of things
http://hand-tools.hardwarestore.com/...ctor-sets.aspx
Before I left the navy I ordered a set like this http://hand-tools.hardwarestore.com/...ctor-sets.aspx for my shop, which came in very handy a few times.
Old Feb 12, 2009 | 07:39 AM
sos's Avatar
sos
Yep, the one you saw on TV was the Grabbit. Sears also has something very similar, which I think they simply refer to as a "Screw Out Damaged Screw Remover."
Old Feb 12, 2009 | 07:49 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I always wondered if that product works.
Old Feb 12, 2009 | 08:28 AM
HammerZ71's Avatar
HammerZ71
I've got a set, I've never had to use them on a vehicle yet, thank goodness. But the two or three times I've used them for rounded out screws they've worked perfectly...
Old Feb 12, 2009 | 10:12 AM
Hoss356's Avatar
Hoss356
Sorry, here's the set I was using in my shop. http://www.amazon.com/Hanson-3101010.../dp/B0013HJF6E
Old Feb 12, 2009 | 11:08 AM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i have a couple different ones...i have the "easy outs" made by craftsman and they work wonders, i also have a set that are used for removing bolts with rounded off heads and i tell ya what....i use them damn things more then often then i put gas in the truck lol
