My engine is doing a weird and anoying whinning noise
Old Feb 13, 2009 | 02:40 PM
raptor700RR's Avatar
raptor700RR
Exclamation My engine is doing a weird and anoying whinning noise
It just happended all of sudden, the egine makes awhinning noise th sound ansgoes in paralelle with the engine usual noise. every time i touch the throttle, the noise is there! Kinda sound a little bittle like a mechanical injection kinda noise. If some of you guys, might have an idea of what my problem can be, please, let me know, thank you very much!
Old Feb 13, 2009 | 02:58 PM
V_Scapes's Avatar
V_Scapes
could be the alternator, does it sound like your rubbing 2 symbols together in a circular motion? i replaced mine at the mileage your currently at.
Old Feb 13, 2009 | 03:48 PM
nathanp's Avatar
nathanp
if it was the alternator the vehical wouldnt run properly though would it?? Im curious cause i might have the same problem
Old Feb 13, 2009 | 05:13 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
you vehicle will still run fine with a bad alternator. at least it did on mine. IT could also be a poor pulley or the power steeting pump.
Old Feb 13, 2009 | 05:53 PM
V_Scapes's Avatar
V_Scapes
it cant be the power steering pump cause he said it gets louder when he gets on the gas, same thing happened to mine, the alternatore could be ready to die...and if it did hed be in trouble.
Old Feb 13, 2009 | 05:56 PM
06CountryBoy5.7
true ture, sounds like your alteranator is about to fail But still could one of you pulleys. Put your ear up to them, have your buddy or wife step on the gas.
Old Feb 13, 2009 | 05:59 PM
V_Scapes's Avatar
V_Scapes
i think you can test them somehow also to see if the charge or output is low. id get on it soon.
Old Feb 13, 2009 | 06:47 PM
BEAR's Avatar
BEAR
I had a whining noise in mine, come to find out after changing the alternator, the tentioner pully it was the Idler pulley. So if I was to give advice I would say start there. They are pretty cheap and not hard to replace. Oh... by the way...the rear bearing in my alternator was going out but it was the Idler pulley making the loudest noise.
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
serpentine idler pulley?
Old Feb 13, 2009 | 09:04 PM
kah1010's Avatar
kah1010
I would check the alternator, however an alternator can make the noise, while it is still OK, if there is a heavy electrical load, thus you may want to check your battery too. One of my German made cars had exactly same "noise symptoms", but turned out that my battery was gone (instead of alternator what I was worried about).
K
