Rear Lift Blocks?
Old Feb 16, 2009 | 10:18 AM
dodge it then ram it's Avatar
Learn to type faster...
How about you freakin slow it down a bit!
Old Feb 16, 2009 | 11:40 AM
Redone4x4's Avatar
Redone4x4
thats a good point hammer...1" blocks would be alright. If you can get the lift you want out of the shackles, all the better. just the ideal of a "block" mixed in the rear axle with axle wrap, wheelhop, etc. that goes on back there automatically deters me...but it really is the larger blocks you have to worry about.
Old Feb 16, 2009 | 11:49 AM
dodgenitto's Avatar
dodgenitto
Originally Posted by HEMI07
My 07 1500 has a 3 in body lift, 2.5 in leveling kit and 35's. i would like the rear to sit 1-2 inches higher to level the truck out better. it looks like it sits a little higher in the front. anyone know who makes a 1in, 1.5in or 2in lift block for my truck? any other ideas?
Or you can go with an add-a-leaf?? I have 3" torsion keys, 3" body lift and 3" add-a-leaf. It makes the rear sit higher at first, but once the leaf gets broken in, it will settle at about a 2" lift.
Old Feb 16, 2009 | 12:48 PM
HEMI07's Avatar
HEMI07
i looked for AAL for my 07 1500 and couldn't find any
Old Feb 16, 2009 | 03:48 PM
ThunderedRod's Avatar
ThunderedRod
I have 3 inch BDS blocks and BDS U-bolts. The shop I bought them from told me that he put the kit together himselft. (Bought the blocks and U-bolts directly from BDS) He said not companies make a block kit for the newer trucks yet.
Old Feb 16, 2009 | 04:58 PM
HEMI07's Avatar
HEMI07
do you have pics of your truck you can post?
Old Feb 17, 2009 | 06:02 PM
Thats bs. If your truck still has the 9.25 axle, you can use any block and u bolts. Just as long as the bolts have the right dimensions.
Old Feb 17, 2009 | 11:54 PM
nohillbilly's Avatar
nohillbilly
I bought a 2 inch block kit from Advance Auto Parts and had new U bolts made at a local spring shop.
Old Feb 18, 2009 | 05:07 AM
UP_Boilermaker's Avatar
UP_Boilermaker
Rough Country offers a set of 1.5" rear blocks with some of their leveling kits.
Example: http://www.roughcountry.com/dodge_4wd_leveling_kit.html
I'm sure you could just get the blocks from them, if that's all you needed.
Old Feb 18, 2009 | 04:04 PM
HEMI07's Avatar
HEMI07
Thanks! i just called them and they have the rear 1.5 in blocks and U-bolts for $49.95.
