will 285/70/17's fit?
Old Feb 20, 2009 | 05:44 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
Originally Posted by Army_HEMI2WD
throw on a small lift. and get some wider rims with some backspacing and she'll look beautiful. got the same size tires, and a 3 inch lift, just need new rims to complete the setup. just curious what kind of tires are they. im running BFG mud terrain KM2s.
mine are hankook dynapro atm's relatively new to the market and now destroying many of older designed all terrain tires. read the reviews.
Old Feb 20, 2009 | 05:46 PM
06CountryBoy5.7
Originally Posted by Ridinhigh
i have the 285/70/17 with no problem and could you fit a 35/12.5/17 on the stock wheels if you buy the spacers for it because that is what i am wanting to do with a level is put a 35 because 33's are pretty much what i have but wanting to know if you can fit the 35 on the stock rim
You can not put a 12.5'' tire on an 8'' wide rim. well sure you physically can but you are going to have some severe cupping and tread wear.
Sure you can fit a 12.5'' tire with a wheel spacer but need wider rims.
