Radiator
Old Feb 19, 2009 | 01:18 AM
tafet's Avatar
tafet
Default Radiator
Hello, I was wondering if anyone knew if the radiator on an 04 1500 would fit into an 03 1500. I know that the 04 had the radiator cap on the radiator. From what I've looked up the only diffrence in measurements was the 04 radiator had a little more core depth. I'm asking because the other day I was looking at a fan shroud delete kit at moesperformance and I might do it if the 04 radaitor will fit. Thanks
Old Feb 19, 2009 | 01:32 AM
irelandshemi's Avatar
irelandshemi
i think it should fit have no idea tho so im sure someone that knows will chime in
Old Feb 19, 2009 | 03:28 AM
Redone4x4's Avatar
Redone4x4
03-05 should be the same...however, and i really dont know, if they put different size radiators in them depending on tow packages or not. my build sheet says i have "heavy duty engine cooling", its something to ask about when you are looking for, Im not sure if there is a difference or not. my 04 radiator crapped out at 49000 miles, had to replace it already.
