Tire fitment?
Old Feb 22, 2009 | 01:01 AM
nodakbassmaster's Avatar
nodakbassmaster
Default Tire fitment?
I've searched around, but can't figure out if the 275/65/20's I am thinking about will fit under my stock 06 3500... any insight?
Thanks for any input!
Old Feb 22, 2009 | 02:57 PM
Wanderer's Avatar
Wanderer
Exclamation
The tire will fit with no problem, but can you get a load range to match your truck's GVW? Make sure the rims are also rated for the weight.
Old Feb 22, 2009 | 03:09 PM
nodakbassmaster
Yup, couple manufacturers make them in an E rating.. still trying to find out the capacity of the Incubus Grim wheels I'm lookin at...
Thanks for the help!
Old Feb 22, 2009 | 05:04 PM
dirtydog's Avatar
dirtydog
Moderate User
Generally they are capable of supporting at least the manufacturers ratings. They wouldn't put 8 holes in a wheels and sell them for trucks if they couldn't handle it
Old Feb 23, 2009 | 12:21 AM
nodakbassmaster
if I recall correctly the stock rims are rated around 3700lbs each, finding an aftermarket rim within a couple hundred pounds of that has been tough! I've found a bunch I loved, but the weight ratings seem to hang around 3K ea for most rims...
Most of the E rated tires are around 3600 to 3800 lbs each...
