I hate this surging/jerking light throttle!
Old Mar 2, 2009 | 12:53 AM
Fris's Avatar
Fris
bump to the top, i need some help please
Old Mar 2, 2009 | 02:07 AM
traker1001's Avatar
traker1001
Stock tunes are backed up to the SC's computers when you plug it in, So its still there. As far as the jerkyness, I havent had any problems, My truck works great with all the SC tunes. I suggest you contact SC directly or goto flashpaq.com and post the issue on there forum, They would probably be better suited to assist.
Old Mar 2, 2009 | 08:33 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
you might want to PM the superchips guys
Old Mar 2, 2009 | 08:53 AM
HammerZ71's Avatar
HammerZ71
You don't need to go back to stock just to update your tune on the truck. You need to get on http://flashpaq.com and have them walk you through using the product correctly. They may not get to you right away, but when they do, they have very good support...
Old Mar 2, 2009 | 11:35 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
x2. There is no need to go back to stock prior to updating your tuner. I have done it numerous times without issue.
Old Mar 2, 2009 | 12:26 PM
dirtydog's Avatar
dirtydog
Moderate User
I'd check your t/b and IAT valve for carbon build-up.
Old Mar 3, 2009 | 12:19 AM
Fris's Avatar
Fris
Ok, thanks for the help.
Tonight I put the truck back to stock. And I have no more jerking or anything weird. But man what a difference it makes. On the stock map with the same driving style I get shifts much quicker. Like I go 1st, 2nd, 3rd gear just cruising from a stop sign. Before with the superchips tune it would hold the gears longer and maybe shift 1st to 2nd on light throttle.
So now what? Why would the superchips tunes cause this?
And my TB and IAT valve I will have to check. When I changed my plugs at 65k I noticed the TB was a little dirty and I cleaned it. BUT I did not remove it to clean the inside half of it.
What is the IAT valve? I know there is an Intake Air Temp sensor, but a valve?
Old Mar 3, 2009 | 01:02 AM
traker1001's Avatar
traker1001
SC is designed for more power first and foremost, Staying in the earlier gears long gives you that higher power and torque. This same thought is used in tow/haul mode, and WOT, no matter what or whose tune you use.
I guarentee the inside is worse than the outside was.
Old Mar 3, 2009 | 01:16 AM
Fris's Avatar
Fris
I doubt it's the TB being dirty since I only got it with the superchips tune. But yeah cleaning the TB won't hurt.
I alrady update the tuner. I guess I will have to try asking on the superchips forum like hammer suggested.
Old Mar 11, 2010 | 11:40 PM
Dodge Spiders's Avatar
Dodge Spiders
Default about ur tranny issues
i had the same problem.. put your parking break on .. put your truck in drive...and check the tranny fluid see if its in the ok zone if not add fluid it sounds like a pressure issue when your driving the pressure stays up when you stop the pressure shuldent drop by much unless the fluid is low which in this case only trying this may fix the problem atf-4 fluid only.. alright well i hope this helps you because i was having the same problem and it fixed my issue ...
