Incorrect Purge Flow, how to fix?
Old Feb 23, 2009 | 06:09 PM
HollowPoint40's Avatar
HollowPoint40
Thanks for the detailed responses, i will get under it and check soon.
So how much is this affecting the vehicle, performance, anything? What would happen if i never changed the line, what difference would it make?
Old Feb 23, 2009 | 06:10 PM
04-fourseven's Avatar
04-fourseven
My brother in law has a crew cab fx4, 6.4 powerstroke. No matter how he drives it, easy and cool, or heavy and hot, he get 12 MPG. 14 on the freeway if there a tailwind, and he resets the mileage on a downhill slope in neutral. My dads 02 excursion with the badass 7.3 got 21 MPG on the highway. WTF!!!
Old Feb 23, 2009 | 06:11 PM
HammerZ71's Avatar
HammerZ71
It's my understanding that a "minor" leak in the evap system is just an annoying CEL, the PCM doesn't change a thing as far as driveability or performance. You ought to clear the code and see how long it takes to come back, that will also tell you as to the severity of the leak...
Old Feb 23, 2009 | 07:35 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Sadly, I know a lot of guys having major problems with their CTD 6.7s that you NEVER heard of with the 5.9!!!
heh....you don't wanna know what kind of **** i saw when I was working as a tech at the dealer....I was the only Dodge Tech at this dealer, and everyday it'd be guaranteed that we'd have 5 CTD trucks come in with some sort of issue.....it's rediculous, however...Cummins was working on getting a new exhaust into circulation that was suppose to fix alot of issues, but not sure if it's gotten there or not....haven't heard from my sources at Chrysler as of yet
but ya know, if you called STAR Center about it...they would tell you to replace the entire exhaust and to give the customer this DVD about not letting the truck sit and run....usually with a diesel, you'd start er up and never shut it off till you were done with it for the day or whatever...with the 6.7 and having the DPF and all that ****, they want ya to shut it off if it's gonna be idle for 5 minutes or longer
Old Feb 23, 2009 | 09:39 PM
HollowPoint40
How would you clear the code? Unplug battery or something?
Old May 22, 2013 | 01:50 AM
SoCal805Guy's Avatar
SoCal805Guy
Just today had my '98 Ram 2500 looked at for this code. My mechanic found that the vacuum directly next to the Leak Detection Pump was apparently installed/plugged in upside down. I've heard this is a bozo common mistake. Apparently the electrical wires are supposed to be on top, not the bottom. We matched up the tubes how they're supposed to connect and cleared the check engine light. So far no more problems, yet. This is an easy, quick check that would be worth checkingg out.
