Mopar Cams
Old Mar 3, 2009 | 04:31 PM
truckin151's Avatar
truckin151
Question Mopar Cams
Just curious about this. I found a link to the 09 mopar performance parts catalog and saw that they have cams available for the 5.7L, so I was wondering if they will work in our trucks? There is also no hp/tq ratings on them just the specs of the cam so if anyone can translate that into numbers I can understand it be great.
This is the link,
http://www.mo-pod.com/pdf/09_Perform...log-120908.pdf
The cams are shown on pg 36
On a side note there is no "Cam" section on the Faqs page....
Old Mar 3, 2009 | 04:55 PM
ramhunter9's Avatar
ramhunter9
im sure hammer will chime in on this one ...bump to the top im curious too
Old Mar 3, 2009 | 05:16 PM
truckin151's Avatar
truckin151
I'm hoping it will work.... Where's Hammer at?
Old Mar 3, 2009 | 05:21 PM
ramhunter9's Avatar
ramhunter9
hes comming he starts from the top and reads everything your next lol
Old Mar 3, 2009 | 05:29 PM
Hoss356's Avatar
Hoss356
It sounds like it would work on 05 and under 5.7's, due to MDS. With a lift of .500" and .488" intake and exhaust respectively, it sounds like a decent street cam although admittedly I do not know what the stock grind is.
Old Mar 3, 2009 | 05:48 PM
truckin151's Avatar
truckin151
I am fairly sure it should be different than the stock cam as I doubt they would call the stock cam a performance cam.
Old Mar 3, 2009 | 07:09 PM
HammerZ71's Avatar
HammerZ71
Who the hell is beckoning for me now, Ramhunter1 had to damn yahoo me during dinner cause this was just so damn important...
Yes the Performance Cam will work in any 03-05 non-MDS 5.7 Hemi. Will not require any additional tuning, and only really needs beefier springs and retainers. The Mopar 6.1 springs and retainers are cheap and would be plenty strong enough.
It's not an '09 item, they've sold it since at least '05 if not before. It's relatively inexpensive as cams go, but unless you can change it out yourself, labor will kill. The going rate for labor on a cam swap is about $800 and I've seldom heard of anyone getting it done for under $600. Very labor intensive. IMO you gonna pay upwards of $800 on a cam swap in labor, spend a little extra and get a much better performing cam. Crazy Jay, Spartan and even a Comp 260 would outperform this one and still not require custom tuning.
The big issue with the cam is, just like the 6.1 cam, which the specs on this one is just under, it's a high LSA cam, meaning it's gonna give good HP gains up high, but lose torque down low. It's a cam much better suited for an LX Hemi or maybe a RCSB 4x2 lowered truck.
You got a heavy truck, like a Quad Cab or 4x4, or BOTH, you really want a lower LSA cam, 112 tops. Don't have the lope of a high LSA cam, but has gobs more torque...
Old Mar 3, 2009 | 07:20 PM
Ridinhigh's Avatar
Ridinhigh
Wouldn't a newer cam not work because the 05 and under Hemi does not have MDS and the new ones do so it seems like it would work but could be wrong
Scratch that post...I read the original wrong and was thinking about putting a 09 hemi cam into an 05 but instead he is talking about the 09 catalog my bad guys
Old Mar 3, 2009 | 07:56 PM
Hoss356's Avatar
Hoss356
Originally Posted by ridinhigh
wouldn't not work because the 05 and under doesnt have mds and the new ones do so it seems like it would work but could be wrong
huh?...
Old Mar 3, 2009 | 07:58 PM
ramhunter9's Avatar
ramhunter9
well hammer this was right up your alley with your super cam and all no harm no foul
