Put in a rack, now I need tires??!
Old Mar 5, 2009 | 07:49 PM
cheapbeater's Avatar
cheapbeater
Default Put in a rack, now I need tires??!
Yep, I put my rack and pinion in last night, and got the front end aligned. The alignment shop said it was all straight, but it still pulls a little to the left... a little was an understatement. It pulled hard to the left, and when turning left, the steering wheel would wobbbbbble. I rotated the tires in an X pattern, and it did the same thing now to the RIGHT! So I switched the front tires around, and it started to pull to the LEFT! I did every tire combination possible, and have come to the conclusion that I only have one good tire...
Shat,,, the only way I can see to fix this is new tires, and I hadnt planned on buying tires for the 20" wheels... I was going to get some black/aluminum wheels with some Nitto grapplers, but I dont know what to do now? $800+ for 20" tires, or $1300 for 4 new motometals with nittograpplers mounted and balanced???
Old Mar 5, 2009 | 07:54 PM
V_Scapes's Avatar
V_Scapes
looks like the 1300 for wheels and tires would be a much bettr option if you want to drop the dough on em. i just did cooper zeons from direct tire discount and after the tires, balance and mount and alignment it all came to about $1050. but be aware your alignment might still be way off, thats the biggest thing that makes a steering wheel shake violently, its known that alot of guys dont truly know how to use a alingment machine, chekc it out before you get new meats.
Old Mar 5, 2009 | 08:50 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i'd take it another shop and have em check the alignment....but if you do end up needing tires, i'd drop the 1300 on new wheels & tires then sell the stock 20"
Old Mar 5, 2009 | 09:13 PM
matty_p's Avatar
matty_p
I had the dealership screw up my alignment right after they had their alignment machine put in. Than they told me that my truck (just a 1500) was too big for it. Went to a local tire shop and they did it cheaper and did a way better job. Find a good shop and stick with them.
Old Mar 5, 2009 | 11:37 PM
cheapbeater
I have always gone to this shop, and they have always done a pretty good job.
The reason I dont think it is an alignment issue is because when I rotate tires, it pulls in a different direction.
For example, it pulled left, so I switched the front tires around and then it pulled right.
On one of the tires I can see a hump on the inside all the way around the tire, I'm thinking it is a belt, that would definately make it pull...
DAM... I really didnt want to buy tires yet,,, anyone out there have a set for cheap??
Old Mar 6, 2009 | 09:23 AM
V_Scapes's Avatar
V_Scapes
oh well if you have a bump on one of em the belt definatly let go, i just went through this whith my crap stockers. yea you need new tires for sure, i wouldnt keep driving on those tires in a fear of a blowout, isnt your whole truck vibrating!?
Old Mar 6, 2009 | 10:49 AM
traker1001's Avatar
traker1001
If you do just new tires your out 800 buck. Do new wheels and tires your out 1300 bucks, However the 20's you can easily get 600 bucks for off craigslist, ebay or even here. making you out only 700 bucks after all is done.
I am assuming from the price, Your looking at 17" Motos with about a 295/70/17 wheel?
Old Mar 6, 2009 | 04:22 PM
cheapbeater
yeah, i am looking at moto 958 black/aluminum with nittos...
could i really get that much for the stockers?? they are in good shape except where some idiot put the weights on the outside of the wheels and corroded the chrome
Old Mar 6, 2009 | 04:29 PM
V_Scapes's Avatar
V_Scapes
you can get new zeons ltz for around 600 from discount tire direct if you dont get the warranty for them. but if you really want the new rims and shoes looks like now is prime time.
Old Mar 6, 2009 | 05:00 PM
cheapbeater
so how do you like your zeons? i had wanted something a little more agressive, but the pirce seems right, and i dont have much $$ to throw around right now
