Audio equipment placement
Old Mar 7, 2009 | 07:10 PM
syn65's Avatar
syn65
Default Audio equipment placement
trying to figure out where to put my cap. And just before everyone starts a war i have read all the pros and cons and figure for what i want it to do, which is ease the load on my alt since my lights dim pretty good, it will work just fine. And no i dont have super set-up as you can see so a high output alt or another battery would be expensive overkill. So anyway, i was wondering where other guys have put em, I was thinking under the drivers seat next to the amp. If so how do i go about taking the drivers seat out, is it just remove the bolts ? Any help/suggestions would be appreciated.
Old Mar 7, 2009 | 09:03 PM
draco8494's Avatar
draco8494
im guessing you have a reg cab? if so yeah under the seat is about the only place you can put it, and the seat should just come out with some bolts unless you got power seats??
Old Mar 7, 2009 | 09:05 PM
raminator08's Avatar
raminator08
theres no room behind the seat? you could try to mount it the sub box
Old Mar 7, 2009 | 09:48 PM
syn65's Avatar
syn65
Got a quad cab, subs are in the cubby holes
Old Mar 7, 2009 | 09:49 PM
syn65's Avatar
syn65
oh and i do have power drivers seat, kinda looks like i have to take out the whole driver's, middle box/seat,
Old Mar 7, 2009 | 10:16 PM
raminator08
i have a question on your system. it says in your sig that you are not happy with the rockford fosgate speakers in your door. are they 6x9s? whats wrong with them? i just purchased a pair of Punch P1694
http://www.crutchfield.com/S-EDULOgm...ate-P1694.html
Old Mar 8, 2009 | 12:54 AM
syn65's Avatar
syn65
Not the ones you grabbed, i have a component set, the duel tweeter setup if the helps. And i have found that some of the s sounds come out scratchy, as well as some low end distortion on certain songs. I will say i love my subs though, plenty of kick and will make my ears ring. My speakers sound all right but the s scratch drives me nuts sometimes
Old Mar 8, 2009 | 12:59 AM
raminator08
ok good then. most people here who i talked to recommended me these speakers and said they sounded really good. i cant afford a component set so i just stuck with regular speaker set
