another v6 with a chip...
Old Mar 8, 2009 | 05:38 PM
keithchambers's Avatar
keithchambers
Default another v6 with a chip...
hey guys. i signed up because it seem yall know alot about the trucks. I have bben debating about getting the jet chip. stage 2 ofcourse for my ram. seems like they do a good job. Heres my problem, the only place online i can find the stage 2 is on the jetchip website. and its reall expensive. its like 330 bucks. Can anyone here send me a link or point me into the right direction of finding one for cheaper. thanks guys!
ps. also, can i use the stage 2 chip from like the 3.7l nitro?
Old Mar 8, 2009 | 05:52 PM
SilverBullet08's Avatar
SilverBullet08
http://superexhaust.com/details/inde.../3888/73872464
chambers's Avatar
chambers
Try autoanything.com they have the stage 2 and if you google for autoanything coupons you should be able to get it around 220 after coupon. For the v6 there are only 2 options really, one is the jet chip and the other is to have B&G do a performance pcm/ecm flash. Try this coupon code "DAYLIGHT" it ends up at about 210 after the coupon.
Old Mar 9, 2009 | 10:06 AM
keithchambers
thanks guys. tha helped alot. but like on that super exhaust website. it says that chip is for every truck known to man kind, except for my truck lol. I have the 2007 st v6. Am i missing something? or can i use is even if it says 08 or 06 standered cab? If thats the case im buying it.
Old Mar 9, 2009 | 11:39 AM
SilverBullet08
it will work i just put in 06 bc i didnt know what year yours was but i could tell by you headlights it was an 06-08.
http://superexhaust.com/details/inde.../3889/73866684
Old Mar 9, 2009 | 05:28 PM
chambers's Avatar
chambers
Yea that is the right one, I double checked it with Jet's site and that's the one for you. For some reason autoanything is giving the wrong part # even when I put in the 07 it is still 90401S when it should be 90402S. If you order from autoanything make sure you call and get that straight.
Old Mar 9, 2009 | 05:34 PM
keithchambers
cool guys. this is much appreciated. I just ordered it from auto anything using the coupon. awesome :]
hey whats gonig to happen if i dont have 180 degree thermos?
Old Mar 9, 2009 | 06:15 PM
Pyro's Avatar
Pyro
I Beat Tetris
Just a little friendly advice from a former Jet Chip owner: cancel the order and save your money or buy a superchips or SCT. The gains from the Jet Chip are barely noticeable, the only thing it improved were the shift points, and marginally at that. It's not worth the increased price at the pump and the two hundred and some odd dollars for the chip. Just a personal recommendation.
Old Mar 9, 2009 | 06:34 PM
keithchambers
Il take my chances.
Old Mar 9, 2009 | 07:47 PM
chambers's Avatar
chambers
He has a v6 and as far as I know they don't have any tunes for them. Only other option is B&G and to do that you need a spare pcm or to send them your's and be w/o your truck for a little while.
Kieth, Derrick also has a stage 2 and he doesn't have the t-stat so I think you are alright. Go to the v6 specific area and ask him about his if you want.
