Axle fluid volume
Old Mar 10, 2009 | 12:02 PM
syn65's Avatar
syn65
Default Axle fluid volume
Might be kinda a silly question but, when the manuel says driving axle they are talking about the diffs right ?, and also how much fluid do they hold ? Need to know how much RP to buy before gettting them changed.
Old Mar 10, 2009 | 12:35 PM
dodgerules86's Avatar
dodgerules86
Fluid to use:
FRONT AXLE
C205F - MoparT Gear Lubricant 75W-90
9 1/4 AA - MoparT Synthetic Gear Lubricant 75W-90
9 1/4 AA EL- MoparT Synthetic Gear Lubricant 75W-90
REAR AXLE
9 1/4 - MoparT Synthetic Gear Lubricant 75W-140
10 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
10 1/2 AA EL- MoparT Synthetic Gear Lubricant 75W-90
11 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
248RBI - MoparT Gear & Axle Lubricant SAE 90
NOTE: Trac-LokT differentials require Limited Slip Additive in the lubricant. Trac-Rite™ / Trac-Rite EL™ differentials DO NOT require Limited Slip Additive.
Amount to use:
FRONT AXLE ± .03 L (1 oz)
C205F 1.6 L (56 oz.)
9 1/4 AA 2.2 L (76 oz.)
9 1/4 AA EL 2.2 L (76 oz.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.)***
10 1/2 AA 2.5 L (85 oz.)
10 1/2 AA EL 2.5 L (85 oz.)
11 1/2 AA 3.6 L (122 oz.)
248RBI (DANA 60) 2.8 L (46 oz.)****
**** Add 147 ml (5 oz.) of Limited Slip Additive
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
Old Mar 10, 2009 | 03:18 PM
BEAR's Avatar
BEAR
I think it was about 3 quarts of each requires weight should do it and if you put Royal Purple in you don't have to add the LS additive. I e-mailed Royal Purple Tec. about that before I changed mine.
