Thinking about diesel
Old Mar 15, 2009 | 09:49 PM
V_Scapes's Avatar
V_Scapes
the 1500 hemis can pull around 6k pounds, so youd be able to pull that baby easy. but like i said, its your money.
Old Mar 15, 2009 | 09:55 PM
Rojhan's Avatar
Rojhan
Sure, they can *pull* 6K pounds easy. They can't *carry* 3,500lbs though (and neither can the 2500).
Old Mar 15, 2009 | 09:58 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
can PULL. I think he's talking about a camper that's IN the bed. even the 2500 can only handle about 3500-4000 lbs. 3500 is around 5k I think.
Being able to pull some weight is one thing. but doing it all the time, that's a whole nother story.
Maybe i'm understanding this wrong. if you only use this a couple times a year, then yes, Hemi will suffice and you'll save money by getting it. but a camper, to me, is something that doesn't come off often, and if its gonna get driven all the time, get the CTD.
Old Mar 18, 2009 | 01:38 PM
Rojhan's Avatar
Rojhan
So, I did some more research (more than the dealer was willing to do, apparently).
Going from a Hemi, 2500, 4x4 QC shortbed, SRW to a Diesel, 3500, 4x4, QC longbed, I only gain about 300lbs of payload (diesel makes a helluva subtract from payload).
In order to get more than that, I need to go dualie, and I really don't want a dualie as a daily driver. On the other hand, it increases my existing payload by 2,000lbs.
Oh, well. I'll stay where I'm at.
Old Mar 18, 2009 | 02:21 PM
xfeejayx's Avatar
xfeejayx
wow, i would have thought it was more than that. but i guess you would be limited by tires and bearing load at that point.
Old Mar 18, 2009 | 03:07 PM
09W3500's Avatar
09W3500
Smile
...the cummins is a 6k option and deisel repairs are EXPENSIVE! not to mention the price of diesel and about a 14qt oil change. diesels aren't that big of an issue in the cold you just gotta keep condensation fromm getting into the fuel and fuel lines and have to either keep a block heater plugged in for the cold weather and gotta warm it up in the morning or else it won't run...
My 2009 Cummins 6.7L came with a 5 year/ 100,000 mile warranty (which is longer than the truck it came in). My truck came with a block heater and battery blankets. I haven't had it long enough to know if it will start in -0F conditions without being plugged in, but it will start when it's +0F (without being plugged in). When I had a gas engine truck ('80's-90's) I had a block heater installed because faster warm-ups = greater efficiency.
My 6.7L oil capacity is 12 quarts. (My old 7.3L Powerstroke held 14 quarts).
My impression (and hope) is that a lot of the bugs have been worked out of the 6.7L Cummins. It is a lot quieter than my 7.3 was (especially on cold mornings) and it warms up faster, too.
