Truck wont start again!
Old Mar 21, 2009 | 03:39 PM
Ram_It!'s Avatar
Ram_It!
Default Truck wont start again!
i tried seaching but how do i get my codes to show up
Old Mar 21, 2009 | 03:51 PM
HammerZ71's Avatar
HammerZ71
It's the weld job man, you know it's that friggin weld job's got the whole truck messed up!!!
Old Mar 21, 2009 | 04:48 PM
BEAR's Avatar
BEAR
I'm not sure if the 08s do it or not but on my 05 you turn the ignition on(don't crank just on) off, on, off and on and the codes appear in the odometer window.
Old Mar 21, 2009 | 05:44 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Must be the predator
Old Mar 21, 2009 | 06:13 PM
sos's Avatar
sos
Wow I didn't know tailpipe herpes could make a truck go downhill so fast.
Old Mar 21, 2009 | 06:30 PM
Ram_It!'s Avatar
Ram_It!
i toke the preator off my buddy thinks its my fuel pump could that be it
Old Mar 21, 2009 | 06:33 PM
nim81's Avatar
nim81
turn the key on and check the fuel pressure checker thing on the fuel line..
if it squirts your fuel pump is good
Old Mar 21, 2009 | 06:50 PM
Ram_It!'s Avatar
Ram_It!
ill have to try that tonight when i go get my truck i had to leave it out in the woods with my quad
Old Mar 21, 2009 | 07:11 PM
traker1001's Avatar
traker1001
please elaborate, What checker thing on the fuel line where?
Old Mar 21, 2009 | 07:17 PM
nim81's Avatar
nim81
ugghhh i can never remember what its called (the technical term)
it looks like a valve stem on a tire, and has a cap on it just like a valve stem, its threaded so you can check your fuel pressure at the rail with a fuel pressure gauge, im not sure where theyre at on the hemi or 4.7 but every vehicle ive ever looked at had one somewhere on the fuel rail on the engine..
just take the cap off, and use a screwdriver or ball point pen, (somthing small enough to press down on the check valve) if the key is on the fuel pump will pressurize the fuel lines, so fuel will squirt out when its pressed.
does the engine crank over and will not start or does it act dead and not crank over??
i must have missed a previous post somewhere
