Check Engine Light on and off with fillups
Old Mar 25, 2009 | 09:27 PM
med511's Avatar
med511
Default Check Engine Light on and off with fillups
2004 Ram 1500 5.7 hemi. Check engine light came on out of nowhere. Had only driven 1/2 mile or so. Had 1/4 tank of gas. Filled up and light went off until at 1/4 tank again days later. Any ideas without getting code checked? Gas cap maybe? Filling up again tomorow. Will see if it goes out again. Thanks
Old Mar 26, 2009 | 01:01 AM
Fris's Avatar
Fris
yeah might be a bad gas cap.
Old Mar 26, 2009 | 01:08 AM
denice25's Avatar
denice25
You're right maybe it's a gas cap!!!
Old Mar 26, 2009 | 01:09 AM
Muchmoneyg's Avatar
Muchmoneyg
i would say gas cap, but maybe your fuel lines have pin holes in them or are rotting. Seems like a loss of fuel pressure.
Old Mar 26, 2009 | 01:33 AM
southernbnb's Avatar
southernbnb
i have been having the same problem. almost every time i fill up my light comes on. it doesnt matter how far i tighten the cap when i get gas it comes on. i get out and tighten the cap a few more clicks and it goes away. im fixing to replace my cap. sounds like you are having the same issue.
Old Mar 26, 2009 | 01:39 AM
whiteliquid's Avatar
whiteliquid
Cap fo sho... lol
Old Mar 26, 2009 | 04:43 AM
HammerZ71's Avatar
HammerZ71
cap or leak in the evap system somewhere...
Old Mar 26, 2009 | 08:05 AM
BEAR's Avatar
BEAR
fo sho^^^^lol
Old Mar 26, 2009 | 08:32 AM
med511's Avatar
med511
Thanks guys. Just filled up and light went off. Will try cap and go from there. Hope it's that simple.
MED
Old Mar 26, 2009 | 01:56 PM
jrod197's Avatar
jrod197
try turning your key off and to the on position (where all the fans start up) 3 times and the check engine code should show up on the odometer display and there should be a thread somewhere on here about it. mine was doing similar things. topping off the tank can cause gas to leak down the evap lines and damage the canister. whenever my gas light would come on i would just put in 20 gallons instead of 28 or so it could hold and magically my light went out.
