How do you test for a plenum leak?
Old Mar 31, 2009 | 10:29 AM
Jaytee67's Avatar
Jaytee67
Default How do you test for a plenum leak?
I have a 2002 Ram 1500 ST Sport QuadCab 4x4, 5.9Liter automatic, 82000 miles.
Not sure how to check the plenum gasket without pulling the entire intake manifold. Any help/advice would be appreciated. Thanks!
Old Mar 31, 2009 | 10:37 AM
jagass's Avatar
jagass
I will love to know this too...Need help here...
Old Mar 31, 2009 | 10:59 AM
HammerZ71's Avatar
HammerZ71
Well, first of all you need a Geiger Counter...
Oh wait a minute, that's a Plutonium leak...
physically looking down the TB is the way I've heard tell...
Old Mar 31, 2009 | 11:32 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Can you spray carb cleaner around the seals to see if the idle changes?
Old Mar 31, 2009 | 12:08 PM
SeMiGoD's Avatar
SeMiGoD
Thats what id do...or a spray bottle of water.
Old Mar 31, 2009 | 01:07 PM
Hoss356's Avatar
Hoss356
That's the way I've always known to do it.
Old Mar 31, 2009 | 02:35 PM
abarmby's Avatar
abarmby
Yep, use a spray bottle and spray away. Try to keep the spray area tight, so you can isolate where the leak is.
Hope this helps?
Al.
Old Mar 31, 2009 | 03:33 PM
mopar6spd's Avatar
mopar6spd
you can also use a little torch around the intake- just letting the gas out of the torch. see if that changes the idle. A little cleaner way than spraying starting fluid everywhere...
Old Mar 31, 2009 | 04:14 PM
Ramdamit98's Avatar
Ramdamit98
You'll want to pull the air hat off and look down the throttle body, look for oil pooling in the bottom of the intake. There should be a little oil film inside the intake (that's normal). Your looking for oil pooling, usually in the back corners of the intake. I found it a lot easier to actually remove the throttle body. It's ton easier and you get a better look, more room to shine a flashlight or use a little mirror to get a good look.
There is a procedure to test using vacuum guage.
http://dodgeram.info/tsb/2000/09-05-00.htm
Old Apr 1, 2009 | 12:14 AM
nim81's Avatar
nim81
these are the only 2 things i would ever recommend for this....
