suspension noise
Old Mar 5, 2005 | 05:15 PM
DallasRam's Avatar
DallasRam
Default suspension noise
Why does my front end make noise? Squeaking, creeking, rattles and knocks. it's a 03 ram 1500 4x4 reg cab ,18000 miles, 3.92 gears ,aftermarket 20x10 wheels ,275/60 tires, i had nerf bars but took them off. if you need more info just ask
thanks in advance
Old Mar 5, 2005 | 05:27 PM
magnethead's Avatar
magnethead
Default RE: suspension noise
are the 4x4's on front leaf springs, coilovers, or normal IFS? I'd look at any bushings first. Sounds like they haven't been greased.
Old Mar 5, 2005 | 07:43 PM
jayskynr's Avatar
jayskynr
i am having the same problem with my 03 reg. cab 2wd. sounds like a 50 yr. old truck whenever i go over a bump that is more than 3 inches tall
Old Mar 5, 2005 | 10:48 PM
moparturd's Avatar
moparturd
Might want to lube the swaybar and endlink bushings. That's a good bet for the sqeaking sounds. Good luck.
Old Mar 6, 2005 | 08:55 PM
DallasRam's Avatar
DallasRam
ORIGINAL: mopartodd
Is that something I can do? If so, how?
Old Mar 6, 2005 | 08:56 PM
DallasRam's Avatar
DallasRam
btt
