Disabled ram!
Hi,
As I went to start-up today, my truck appears to be disabled. I get a low tire pressure light (all tires are OK) and my engine won't crank. In addition, my keyless remote now doesn't work.
Any ideas?
Thanks, B
Any ideas?
Thanks, B
Yeah, I'd say it's the key. Either the battery is too weak, or the truck has "forgotten" the key codes. Do you have a spare key? Try that one. If it doesn't work, it sounds like you're going to have to get it to the dealer. Hopefully it's still under warranty?
Yeah it's under warranty....thanks for the speedy reply, much appreciated.
I have a spare key on the way over. Will let you know but my dealer says call a tow-truck. What a pisser.
B
B
Neither key worked. I had full electrical system working except for the starter and the key-less remote.
Ended up disconnecting the battery, reconnecting it, then everything worked fine.
Drove it to the dealer and left it there. Hopefully this is a one-time gremlin.
Thanks again for the replies.
B
B
