help needed
Old Apr 4, 2009 | 01:36 PM
slicer4659's Avatar
slicer4659
Default help needed
Got a bit of a problem, heater core went out on my 02 Ram got the dash all ripped out, heater core replaced and put back together, but there was a month between take out and put back , needless to say, wound up with a few extra bolts.....LOL! and I cant find an exploded view showing all the mounting bolts and or the ground bolts, but anyway heres a pic of the two that are my main concern at the moment. Can anyone tell me where on the dash they go? Thanks.
Old Apr 4, 2009 | 10:14 PM
slicer4659's Avatar
slicer4659
Default found
Well guys, it took droppin the steering column again and the use of a mirror to see, but i found out where they go. theres the 4 mounting studs pointing downwards, the two 10mm bolts go just behind the studs closest to you if you were sitting in the drivers seat, and imean just! behind them. hope this helps anyone else thats runs into the same issue.....lol!!
