door sealing issue.....
Old Apr 6, 2009 | 09:56 PM
hemipower05's Avatar
hemipower05
Default door sealing issue.....
ok so it seems like whenever there is high windows blowing from the passenger side towards the driver side, the driver door seems as if it isnt closed and a loud wind noise starts happen. its almost as if the wind is blowin open the door! its so annoying.... any thoughts on how to fix it?
Old Apr 6, 2009 | 10:59 PM
Redone4x4's Avatar
Redone4x4
there has been issues with the weatherstripping and doors sealing on here...try searching, i dont recall the exact details. i think it was cured by ordering newer stripping or something like that.
Old Apr 7, 2009 | 12:44 AM
Dodgeboy77's Avatar
Dodgeboy77
I had that on the driver side, i had the dealer adjust the door tighter.
Old Apr 7, 2009 | 01:14 AM
jagass's Avatar
jagass
You just take it to dealer for adjustments...
Old Apr 7, 2009 | 03:30 PM
Kebo's Avatar
Kebo
Yep, I had mine done last Friday. They replaced the drip seals on both sides due to a defect. Below is the link to the TSB. If you are still under the 3/36 warranty, they will replace it for free. If not, it will cost you. Mine was $116 for the parts and 30 minutes worth of work.
http://dodgeram.info/tsb/2005/23-049-05.htm
Old Apr 7, 2009 | 10:42 PM
rtmtrrdr's Avatar
rtmtrrdr
If you don't want to spend the money and waste your time you can adjust the door yourself in about 15 mins.I had to do this to all my doors about a year ago and they don't leak,howl ect with no problems with them at all.
Old Dec 26, 2010 | 03:10 PM
olyelr's Avatar
olyelr
Originally Posted by lstough
The designer of the hinge system should be fired, then shot. First there is no limit arm (like on most auto doors) to keep the door from bending the hinge outward when the door is forced opened beyond the limit the hinge itself will allow. When the door swings open hard, like when the wind catches it, the hinges bend away from the frame creating a new pivot point for the door. This is ever so slight but when extended to the top of the door it expands to about 1/4 inch. This in turn reduces the amount of pressure the door has on the rubber gasket causing air to leak in. When you take you Dodge to the dealer, they lie. The are very much aware of the design problem but will only adjust the strike system. Sometimes this helps slightly but is only temporary. Dodge wants you to go away and only come in with problems they can solve. It is suprising that since Dodge new about this problem from the begining, '04 model that they failed to fix it on future model. The service manager at Dodge did give me a tip on how to fix it myself which I tried and sure enough it worked. I read all the posts and suprisingly no one even thought of it. If you want the secret, Id be happy to share. Just contact me.
Wtf? Why not share the "real" fix with the rest of the Dodge community? Thats silly.
Old Dec 27, 2010 | 11:50 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They did come out with replacement door seals. There is a TSB on this. These in combination of properly installed and adjusted doors will keep any air leaks out. Now if your doors are bent from trying to wedge things in between them to unlock them if you locked your keys on the inside, well then they are bent or warped and thats another issue.
Old Dec 27, 2010 | 09:47 PM
olyelr's Avatar
olyelr
Thanks weed, thats good to know! I get air squeeking through quite often.
I bet new seals would be a much better way to "fix" the issue then what lstough pm'd me hahahaha:
Josh E ; Open the door full. Put a jack, like a motorcycle jack under the door close to the end. Jack the door up bending the hinges and where the hinges mount. By doing this the top hinge bends in and the bottom hinge bends out slightly. Now when the door closes the top of the door where it seals will be closer to the door frame causing the rubber to compress more thus making a tighter seal. This worked for me on both doors but must be repeated occasionally as the doors get sprung again. Don't be afraid to really jack with some force but be careful to place the jack so as to distribute the force to over at least a foot so as to not bend the metal on the bottom of the door as the skin is beer-can thick. Good luck.
Old Dec 27, 2010 | 09:50 PM
olyelr's Avatar
olyelr
Oh, and where does a guy get these "new" seals? Parts store, or dealer only item?
