2004 Ram 1500 4x4 Leveling Kit?
Old Mar 7, 2005 | 01:52 AM
hozz's Avatar
hozz
Default 2004 Ram 1500 4x4 Leveling Kit?
I am looking to bring the front end of my Ram up equal to the back, you know, to avoid that low front to high back look. Everything I see is for up to 2001 1500 4x4, and up to 05 only for 2500 and 3500.
Does anyone know of a good leveling kit for an 04 Ram 1500 4x4 QC?
Thanks!
Old Mar 7, 2005 | 02:37 AM
cowboy133's Avatar
cowboy133
Default RE: 2004 Ram 1500 4x4 Leveling Kit?
They are basically all the same. The one I got was from Fabtech. easy install. Or you could just use the springs out of a 2500 which are stiffer and will raise your 1500. Try is sight http://www.rockymountainsusp.com/dodge4_03diesel.htm
Old Mar 7, 2005 | 02:56 AM
mazz's Avatar
mazz
Try this: http://www.truxxx.com/dodge_products...m_lift_kit.htm
Old Mar 7, 2005 | 04:40 AM
Bruce's Avatar
Bruce
These seem very easy to install and cheap http://www.4wheelsupply.com/day/dodge-leveling-kits.htm
Old Mar 7, 2005 | 12:45 PM
shortbus's Avatar
shortbus
ORIGINAL: Bruce
Those wont work on a half ton. The 02-up half tons have torsion bars instead of coil springs. You can crank the torsion bars up a little or replace the keys. I turned the bars on mine and it stiffened up the ride (in a good way) and raised the front end about an inch and a half. Still not level, but much better.
Old Mar 7, 2005 | 10:01 PM
DallasRam's Avatar
DallasRam
