Dumb question about oil......
Old Apr 9, 2009 | 03:21 AM
04-fourseven's Avatar
04-fourseven
I scanned pretty quick through this thread, but if hasnt been mentioned already, with 9*,000 miles on yer truck, it probably wouldnt be a bad idea to switch to synthetic no matter what...
Old Apr 9, 2009 | 06:08 AM
hemidel's Avatar
hemidel
Originally Posted by dirtydog
I think I would stick to 10w-30 with that kind of mileage and if that's what you have been using so far. Why the need to change? Change isn't always good....lol
Just thinking long term. I want to keep the engine going another 90k miles, so, just trying to take care of my baby (truck).
Old Apr 9, 2009 | 07:07 AM
MikeHTally's Avatar
MikeHTally
As long as it isn't leaking/burning, the lighter weight oil shouldn't cause any problems.
Old Apr 9, 2009 | 08:23 AM
BEAR's Avatar
BEAR
EXACTLY! I switched to full synthetic (RP) right at 100k ran great before and runs even better now! Just make sure you don't have ANY oil leaks and you don't use any if not then you should be good to go.
Old Apr 9, 2009 | 09:13 AM
dirtydog's Avatar
dirtydog
Moderate User
If you switch to a lighter weight oil, just check your oil regularly the first oil change to make sure you aren't burning any. You don't have the 5.9L so you'll be fine. Those are notorious for burning oil. Well, everyone i have seen has been low on oil and/or puffing smoke on start up.
Old Apr 9, 2009 | 10:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Has anyone tried the new Castrol Edge Synthetic? Its the same price as the RP.
Old Apr 9, 2009 | 11:28 AM
mfs212's Avatar
mfs212
^Haven't tried it yet. I also switched to synthetic (Royal Purple as well) and it is well worth the extra expense. The engine feels like it runs smoother and responds better. Plus, synthetic allows you more time between oil changes.
Old Apr 9, 2009 | 01:16 PM
Riccs22's Avatar
Riccs22
older engines can leak if you switch to synthetic the molecules in the oil are smaller
Old Apr 9, 2009 | 02:00 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you have leaks now then they just get worse later, tighten the bolts or change out gaskets. I remember when Syn first came out people were saying thjey had leaks but I never knew of anyone personally who had it. Mine doesnt leak.
Old Apr 9, 2009 | 07:53 PM
hemidel's Avatar
hemidel
No leaks at all.... Hum, i got knowledge & opinions here, well, got to think this one over....
