panard bar????(2500)
Old Apr 12, 2009 | 07:48 PM
draco8494's Avatar
draco8494
Default panard bar????(2500)
allright, ive had this slight bump in my steering for about a month now, i thought it was my tie rod ends but i had my GF sit in the truck and turn the wheels left and right, and i see that my panard bar is moving just a slight bit, i thought it was loose from the level install so i tightened it up and no avail, still does it..i cant remember but is there a bushing on it? im thinking threre is but i just wanted some second opinions...thanks!!
Old Apr 12, 2009 | 09:16 PM
Parts/Service's Avatar
Parts/Service
If by panard bar, you mean the track bar. don't believe you can buy the bushings.
Old Apr 12, 2009 | 10:04 PM
draco8494's Avatar
draco8494
so ur sayin ide have to bring it in to get it fixed....? i guess it would be the track bar, the bar that runs from the passenger side axle to the drivers side frame rail, and keeps er all centered up
Old Apr 12, 2009 | 11:46 PM
4217racer's Avatar
4217racer
The track bar on the 2500 does have bushings, cost you less then $20.00 to replace. Much better then having to replace the hole bar like the 1500's.
