Quickie: Does it matter which way the IAT sensor goes?
Old Apr 20, 2009 | 09:51 PM
cheapbeater's Avatar
cheapbeater
Default Quickie: Does it matter which way the IAT sensor goes?
im in the process of making an elbow to connect my ebay cai to my throttle body. but before i glue in the IAT sensor i want to make sure it doesnt matter which way it faces. in other words, can it be twisted 180 degrees and still work fine?
thanks
Old Apr 20, 2009 | 09:54 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
makes no different. The air just neeeds to go by it is all.
Old Apr 20, 2009 | 09:58 PM
cheapbeater
thats all i needed to know, thanks man.
cant wait to get er hooked up... never seen it done like this before
Old Apr 20, 2009 | 10:20 PM
raminator08's Avatar
raminator08
just make sure you properly seal it or you will get a check engine light come on
Old Apr 20, 2009 | 11:53 PM
John  M's Avatar
John M
It will get the truest reading with the air going through it as opposed to over it.
Old Apr 21, 2009 | 06:39 AM
RubberFrog's Avatar
RubberFrog
Don't glue it. Install an oring instead. Trust me, you will need to take it out someday.
Old Apr 21, 2009 | 07:46 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
+1. I wouldn't glue it in bc it is just going to be a headache when you go to remove it one of these days.
Old Apr 21, 2009 | 07:47 AM
dodgenitto's Avatar
dodgenitto
what RubberFrog said! I would use the o-ring! You may have to service it one day and therefore need access to it.
Old Apr 21, 2009 | 09:56 AM
BEAR's Avatar
BEAR
+4 or 5 or what ever!!! Don't glue the AIT sensor in man!! Like everyone has said use a O ring of some sort.
Old Apr 21, 2009 | 12:22 PM
cheapbeater
ah ****... i already glued it in. i'm pretty sure i will be able to get it out if i need to, i used a rubbery silicone type glue.
