04 ABS lights on & motor continuously runs
Old Apr 22, 2009 | 05:04 AM
elly316's Avatar
elly316
Default 04 ABS lights on & motor continuously runs
Hi,
I have a 2004 dodge ram 1500, the brake and abs lights are on and the ABS pump motor continuously runs even with the ignition off. I have pulled the abs motor fuse to stop it running constantly and the normal brakes work fine.
Has anyone seen or heard of this problem before? and fixed it?
Thanks for your help
Old Apr 22, 2009 | 09:37 AM
rtmtrrdr's Avatar
rtmtrrdr
I had a buddy of mine that had a 2nd gen truck and he had the same problem.It was a combination of the switch on the brake peddle had gone out and the abs sensor on the rear end.I don't know if they have changed this on the 3rd gens or not,but i guess it couldn't hurt to check thoose
Old May 7, 2009 | 02:29 PM
elly316's Avatar
elly316
How do I check/test those?
Thanks
Old Mar 11, 2013 | 10:00 PM
joscayey's Avatar
joscayey
Default ABS and Brakes Lamp
Ram 1500 2004 engine 5.7l.Lampara of ABS & Brakes remain lit.
