'08 Hemi 2500 slight knocking?
Old Apr 23, 2009 | 07:36 PM
Rojhan's Avatar
Rojhan
Default '08 Hemi 2500 slight knocking?
2500 Ram, no MDS.
In the category of "new noise", but otherwise not really noticeable...
Under light acceleration between about 2200-2500 RPM I've started hearing that I could describe as either really light dieseling or knocking. I originally thought it was a small exhaust leak, but an exhaust shop ran a stethoscope end-to-end and didn't hear anything (although you can't hear it at idle).
It's really hard to hear with the windows closed, and it's mostly masked by wind/traffic noise with windows open, so it's not "oh no! the engine is going to blow up!"
Anybody else? Anything else to look at? I had a service-writer at a dealer do a road test with me, and he hears the sound and agrees that it shouldn't be there. I'm working on getting it looked at by an actual mechanic.
FWIW, I've never run 87 octane. Usually 89, sometimes 92 (the 92 was cheaper )
I've just turned 6,000 miles, and the weather has also started getting warmer (high 50s/low 60s during the day instead of low low-mid 40s).
Old Apr 23, 2009 | 07:44 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Mine has done that since new also...so don't feel alone
Old Apr 24, 2009 | 04:42 PM
V10Venom's Avatar
V10Venom
Wonder if you're hearing the notorious hemi tick? IDK though, I don't have a hemi
Old Apr 24, 2009 | 11:44 PM
Alpheus's Avatar
Alpheus
I only here Hemi tick @ idle. You are still under warranty right? I would have it looked at ASAP if its a low end knock. I can live with ticks but not knocks...
Old Apr 27, 2009 | 03:36 PM
Rojhan's Avatar
Rojhan
Dealer says "normal" and, like the exhaust drone at ~2,000RPM, it "because of the hemi and the way the muffer is".
