Body lift on a 2wd 06 1500
Old May 1, 2009 | 10:55 PM
Matt99's Avatar
Matt99
a level is a leveling kit....different on different trucks, you might have a bar to crank or put a thick spacer on top of the spring...it is to level the stock rake look, so you dont look like you are in a 3 point stance
Old May 2, 2009 | 01:26 AM
evo8's Avatar
evo8
This is pretty much my truck, sits as high as mine does....
Explain what leveling kit would do to it?
BTW, here is what I want mine to look like. Maybe even a bit higher
or
here is a perfect example of the same color and everything, but just 4x4
NOW I WILL PUT 2 - one below another, so people could tell the difference, maybe I will make myself more clear this way.
Old May 2, 2009 | 11:40 AM
evo8's Avatar
evo8
Old May 2, 2009 | 11:47 AM
nickahern1's Avatar
nickahern1
fords and chevys sit really low compared to even a 2wd ram. if you notice on the 4x4 pic above the front sits lower the front. a leveling kit is a spacer that sits on top of the strut assembly or on top of the spring. it will basiclaly level the fron to the rear ( 2.5 inch kit sits just about perfect) to raise your rear just throw a .5-1 inch block in the rear. i would do both level and block and then throw some meatier tires instead of the garbage wrangler hp's and call it a day. youll have a truck that sits nice.
Old May 2, 2009 | 02:43 PM
DaHipaKea1313's Avatar
DaHipaKea1313
Hey evo8 How about a front spindle lift?? Not sure who it was but about a year ago one of our fellow Dodge Bloggers did it and the level kit too I believe. Looked really cool. Not sure who makes them but do a google for lift spindles I'm sure you'll find them
Old May 22, 2009 | 12:27 PM
hmathews's Avatar
hmathews
I believe you can do coil spacers in the front and back - may be 2.5" in the front and 1" in the back. You may need new shocks in the front...
