07 2500 Diesel Ram Leveling kit
Old May 4, 2009 | 08:42 AM
dmbrazilian's Avatar
dmbrazilian
Default 07 2500 Diesel Ram Leveling kit
Hello, I wanted to know what are some good leveling kits for the 2500 diesel 4x4? I am wanting to get bigger tires and I guess I need a leveling kit. Also what is the biggest tire size that I can go with without the leveling kit?
Thanks
David
07 Dodge Ram 2500 4x4 Quad Cab Diesel Short Bed
Old May 4, 2009 | 08:50 AM
02Steve1990's Avatar
02Steve1990
Hey welcome to DF, there are a few good leveling kits out there like topguncustomz, rough country, skyjacker and there are a few more i can't think of i'm sure someother's will chime in and help me out. As for the tire size w/o a leveling kit i'm not too positive since you have the 2500 you're a bit higher off the ground than a 1500. Try to ask that in the diesel section or do a search for it on the search bar.
Old May 4, 2009 | 07:53 PM
Joel_MD's Avatar
Joel_MD
The general consensus is that you can go with 33" tires on a 2500 without a leveling kit. The Kore HP Leveling Kit is possibly the best one, as it completely replaces the springs with longer ones instead of spacer blocks. You end up with more spring travel.
