Help!!!!!!
Old May 4, 2009 | 05:02 PM
bigtruckman32's Avatar
bigtruckman32
Default Help!!!!!!
I have and 03 hemi and i had a problem with the dinger for the lamp out keep coming on when i hit the brakes and no light were out so i figured i'd find the specific wire that does just the lamp out and cut that one wire on the dinger but instead i found a box under the dash it's only bout a 1/4" thick and a 2"X2" square it has 3 different plug ins one is a four prong which had a black "ground" and a yellow "memory" and a red "ignition" and those were wired in the other is a 5 prong that had nothing plugged in and a 4 prong super small plug in with nothing plugged in but if i take this little box out even though nothing else but a hot memory and ground is plugged to it my lamp out dinger quits if i plug it back in it starts goin of randomly again when i hit the brakes or gas i have no idea if anybody has some suggestion lol
Old May 4, 2009 | 05:32 PM
jk360's Avatar
jk360
try this, take out the rear tail lights and pull each bulb. chech each socket and see if one looks kinda burnt/charred. i had the same thing and didnt see any bulbs out but then looked harder and saw the a socket kinda looked bent in and burnt. so i stuck a small screwdriver in there to kinda pry out the socket tabs and have never had a problem since. also check the part of the bulb that goes in the socket and see if thats charred at all.
Old May 4, 2009 | 06:26 PM
dodge it then ram it's Avatar
Ya what jk360 said. I had the same problem 3 weeks ago but I already new what it was cuz it also happened to me a year ago on a different bulb.
Old May 4, 2009 | 11:57 PM
bigtruckman32
Thumbs up thanks
hey thanks guys did watcha said and definately fixed the problem that dingin was gettin kinda annoying lol
Old May 5, 2009 | 12:04 AM
dodgenitto's Avatar
dodgenitto
Dodge Forum at its finest!
