front drive shaft help
Old May 5, 2009 | 09:28 AM
Lvnspeed's Avatar
Lvnspeed
Default front drive shaft help
I have a 2005 CC hemi Dodge 1500 AWD. The front driveshaft comming from the transfer case to the front differential has an issue. The knuckle just past the transfer case is making all kind of racket and the rubber boot is missing. Is this repaiable or do I need to replace the entire shaft? What is the part I am talking about called? Any help would be appreciated. Thanks
Old May 5, 2009 | 12:32 PM
Cheeech's Avatar
Cheeech
Hard to tell without looking at it. is there a u-joint under the boot? If so, then it's repairable.
Old May 6, 2009 | 06:04 PM
cando's Avatar
cando
That nuckle is called a cv joint. its rebuildable, further up by the differential is the universal it too is replaceable.
Old May 6, 2009 | 10:01 PM
Lvnspeed's Avatar
Lvnspeed
Thanks guys went to Napa and AutoZone no parts for rebuild going to the dealer to see.
