squeeking i know i know
Old May 9, 2009 | 02:20 PM
irelandshemi's Avatar
irelandshemi
Default squeeking i know i know
i have a 03 ram 1500 qc i just noticed today that im getting a squeeking when i hit bumps and whatnot, its fine when i drive straight but every bump makes the noise, any ideas and any ways to tell for sure if that is it. i pushed down on the front bumper and it squeeks so yeah, and if it helps it sounds like its comming from the front drivers side wheel well
Old May 12, 2009 | 06:25 PM
bert6573's Avatar
bert6573
the same thing happened to me....im not sure whats its called...but you have something loose in or around the calipers......when the truck experiances a weight shift the loose piece will scratch on the rotors causing an annoying squeak
Old May 12, 2009 | 07:59 PM
OlDirtyJohn's Avatar
OlDirtyJohn
it could be a whole # of things. most likely ball joints, either upper or lower. but could also be end links, control arm bushings, sway bar bushings... pretty much anything that moves. i know my ball joints are going out, squeeking like crazy. im planning on getting some new upper control arms with greasable ball joints from rock auto, only like $85. have a buddy jump on the bumper while you listen around and pinpoint the problem, or just replace all the bushings and joints with aftermarket greasable ones.
Old May 12, 2009 | 11:16 PM
irelandshemi
i turned the wheel while parked at had my brother look and he said it seemed like it was this metal rid that goes into a rubber boot looking thing, he wasnt 100% sure but he thought so and it does it on both sides regardless of which way you turn
Old May 13, 2009 | 12:32 AM
ried69's Avatar
ried69
My truck makes some squeaks when I turn the wheel all the way. Annoying, and it's because they aren't greasable bearings. And it's all thanks to the people who think that vehicles should be maintenance free.
