No fuel pump help!!!!
Old May 14, 2009 | 03:00 PM
LayinsparxX's Avatar
LayinsparxX
Default No fuel pump help!!!!
Hey guys whats up, i have been having fuel pump problems now for a while.... I have dropped over 1500 into trying to fix this problem.
Does any one know if the fuel pump is some how controlled by the ecm?
or is it simply just relay off keyed power?
I have no power to the fuel pump......
I had the truck up on a jack one day, was trying to see why my A/C pump was not kicking on... I probed one of the 2 wires coming off the AC pressure sensor and all the sudden truck sopped running. has not ran now for 3 weeks.
makes no sense, i unplugged that plug and plugged her back in and still nothing.......all fueses and relays seem to be good
SOME ONE HELP please
Old May 14, 2009 | 03:04 PM
LayinsparxX
Default Ram 1500 NO Fuel PUMP NO REASON
its the ram 1500, forgot to add that in my post
Old May 14, 2009 | 03:58 PM
Alpheus's Avatar
Alpheus
Here is a link to all of the wiring diagrams.
http://www.dodge.com/en/business/body_builders_guide/
Is the pump running at all? Do you have power to the relay? Do you have power at the pump? Did you check all fuses and fusible links? Did you short something out when you probed the AC clutch power? As far as I can see, you could short the AC clutch positive wire and all it would do is blow a fuse.
Old May 14, 2009 | 06:52 PM
MikeHTally's Avatar
MikeHTally
What year? Somewhere along the line, Dodge introduced bump-start.
Old May 15, 2009 | 12:36 AM
LayinsparxX
My truck is a 02, well i borrowed an ECU and plugged it in. my pump RUNS so how did i blow the ecu with a freakin A/C clutch pressure switch
Old May 15, 2009 | 12:40 AM
LayinsparxX
Now im just trying to figure out why my damn rear defrost light keeps flashing. I plugged my ecm back in and NO PUMP AGAIN so im looking for ecm. But only ones i can find are a couple numbers off like mine is a 202AB and found one thats 201AB
whats diff lol?
BUT
