need help ASAP
Old May 14, 2009 | 10:28 PM
beachbummer0069's Avatar
beachbummer0069
Default need help ASAP
Hey yall just about done installing a performance accessories 3" body lift on 08 dodge ram 1500. I rain into a little problem. I can not get the steering shaft back together. I was wondering if yall used the steering sgaft extension that came in the kit? Cuz it seems to long. I tryed to connect the steering shaft back together without the extension and its to short. How did yall get your steering shaft back in when installing the body lift?
Old May 14, 2009 | 10:47 PM
AF_HEMI's Avatar
AF_HEMI
yeah man you gotta use the extension. sometimes you have unbolt the 2 bolts holding the steering wheel column inside the cab, to allow the column to move toward the drivers seat, allowing you to put the extension on. then once you get the extension on you should be be able to slide the column back into its original position.
Old May 14, 2009 | 11:43 PM
beachbummer0069
i just tryed what you recommended and still the extension acts like it is to long.
Old May 15, 2009 | 02:55 AM
04-fourseven's Avatar
04-fourseven
sawzall the SOB.. lol. no dont. lol.. good luck, make sure post pics when you get it done...
Old May 15, 2009 | 02:56 AM
04-fourseven
BTW, AF Im getting ready to ship out to where your at. I live in Bakersfield right now, but I going to be working on platform Irene. So maybe when you guys do test, I can peek around the barrier and give you a nice smile, cause I know you can see everyone of us!!!!
