Trans temp gauge install
Old May 16, 2009 | 12:40 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I am pretty sure that he has that toggle switch so he can switch which sensor the gauge is reading off of so he can compare the temps at the two different points where he installed the senders. At least that is what I would think is going on, but I am just guessing based on his original post.
Old May 16, 2009 | 12:42 PM
SilverBullet08's Avatar
SilverBullet08
oh ok i see the toggle switch now. one sensor is good for me though lol
Old May 16, 2009 | 02:51 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You are right that he can only read one sensor at a time but that's why he has the two sensors wired to a switch (i assume a SPDT switch) so he can flip back and forth between which ever sensor he wants to read from at that time.
Old May 16, 2009 | 08:22 PM
draco8494's Avatar
draco8494
kinda cool, i really want one for my truck, but im thinking about the guage pod that goes in your cubby hole under the radio
Old May 17, 2009 | 01:06 PM
Lifted4x4Astro's Avatar
Lifted4x4Astro
I bought the parts all from egauges.com. The black pod because it is the only color Autometer sells without buying the whole pillar. My dash is black and it looks pretty good. I have 2 sensors installed just because I had the compression fitting. I can only read from 1 sensor at a time.
I must add that I have the largest factory trans cooler offered. It is almost as big as the radiator!
Test results so far...
We did a short towing trip with the camper. I towed in 3rd and our camper is only around 5,000# and is a Jayco Featherlight EXP 232. Trans line temp only got to 150 and trans case was about 15-20 degrees cooler. This trip was only about 10 miles so it was not much of a test. This coming Friday we will be heading on a 3 hour trip up in the hills.
Old May 28, 2009 | 02:44 PM
Lifted4x4Astro
Went on another camping trip over Memorial weekend. Towed about 370 miles up into the Adirondack Mountains. Ran in 3rd the whole trip up and back. Camper tanks were all full...30 gallons fresh, 23 gal grey and 23 gal black (trying to clean sensors). Has 3 bikes on a rack in the rear, 1/3 bed of wood, coolers and all the gear for a family of 4 plus a black lab for a week! (My wife way over packs! ) I got right around 8 mpg. The highest I saw the cooler line temp get to was 195. That was climbing a fairly steep hill in 2nd at 60 mph. I don't baby her just because she's towing. On the interstate, the line temp hovered right around 165. I am very happy with these temps.
Old Jun 1, 2009 | 04:09 PM
nathanp's Avatar
nathanp
are you talking about the cooler on the right hand side??? If so i thought thats for teh air conditioner, i think the little short skinny one ontop of the coolant rad is the tranny cooler... if im not mistaken
Old Jun 1, 2009 | 07:07 PM
Markmm0000's Avatar
Markmm0000
Think he means the one on the left.
Old Jun 2, 2009 | 01:13 AM
Lifted4x4Astro
Yes the one on the left looking at the front. It is in front of the coolant radiator and above the power steering cooler.
Old Jun 9, 2009 | 04:00 PM
truckin151's Avatar
truckin151
That trans cooler, was it orginally on the truck or did you pull it off a different truck? I will be needing one about that size to replace the one I have which by the looks of it is about 3" shorter than the one you have.
