Unlock/Lock Question
Old May 19, 2009 | 06:29 PM
SilverBullet08's Avatar
SilverBullet08
Exclamation Unlock/Lock Question
Ok well I noticed last night when i locked my truck that the lights did not blink when i locked it. they did work after my trans gauge so i dont know whats wrong. but when i has pulled out the light switch one wire did come out. here is a pic of it. any ideas whats wrong??
its the two blue connectors with the white wire at the top
Old May 19, 2009 | 07:00 PM
MikeHTally's Avatar
MikeHTally
Load resistor for something. Sometimes used for LED lamps.
Old May 19, 2009 | 07:04 PM
SilverBullet08
is that why they wont blink when i lock or unlock?
Old May 19, 2009 | 09:57 PM
SilverBullet08
anyone?
Old May 20, 2009 | 01:26 AM
Alpheus's Avatar
Alpheus
That is a load resistor for an LED. Did you put it there? Do the lights flash if you hit the panic button on your FOB? That resistor should not effect the lights unless its shorted to something...
Old May 20, 2009 | 01:40 AM
SilverBullet08
it was there when i opened it up. ill have to try the panic tomorrow. i do have and aftermarket alarm is that means anything...
