how much do u think my truck is worth with this dent??
Old May 19, 2009 | 09:01 PM
sabedra211's Avatar
sabedra211
Default how much do u think my truck is worth with this dent??
lol well i baught it with this dent. at 108,000 miles. for 11,000. its a 2004 dodge ram 4.7 L quad cab. well the dent is on the passenger side and as u can see on the picture the doors have a crease too. the body shop will charge me 2000 dollars to fix it. So if i were to sell it or trade it in would it be worth to fix the dent or not? it now has 113,xxx miles on it. i was wanting a hemi dodge lol. here is the picture and at bottom is the build sheet. Name:  05-19-09_1738.jpg
Its stock i think everything was kept the same Thanks!!
Leather Trim 40/20/40 Bench Seat
Dark Slate Gray
Sport Group
Trailer Tow Group
Monotone Paint
4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
136 Amp Alternator
750 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Brakes
40/20/40 Split Bench Seat
Front Height Adjust Shoulder Belts
Next Gen Multistage Front Air Bags**
Front Seat Area Carpet
Front Floor Mats
Heated Front Seats
Passenger Assist Handle
Rear 60/40 Split Folding Seat
Rear Underseat Compartment Storage
Front Center Seat Cushion Storage
Folding Flat Load Floor Storage
O/Head Console w/Trip Computer/UGDO
All 5-Speed Automatic Transmissions
5-Spd Automatic 545RFE Transmission
Lock-Up Torque Converter
Elec Shift-on-the-Fly P/Time T/Case
205MM HD Front Axle
3.92 Axle Ratio
Corporate 9.25 LD Rear Axle
All Gas Engine
4.7L V8 MPI Engine
Tinted Glass Windows
Rear Sliding Window
Sun Visors w/Illum Vanity Mirrors
Rear View Auto Dim Mirror
Passenger Side Sun Visor w/Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Remote Keyless Entry
Sentry Key Theft Deterrent System
Air Cond'ing w/Dual Zone Temp Cntrl
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Cluster w/Tach
Instr. Panel Satin Silver Bezel
120 MPH Primary Speedometer
Var Intermittent Windshield Wipers
Cigar Lighter
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Locks
Power Windows, Driver One-Touch
Power 6-Way Driver/Passenger Seats
Glove Box Lamp
Ash Tray Lamp
Front Dome w/On/Off Switch Lamp
Underhood Lamp
Halogen Headlamps
Fog Lamps
Cargo Lamp
Security Alarm
Body Color Front Bumper
Body Color Rear Bumper w/Step Pads
Front License Plate Bracket
Body Color Grille
Laramie Badge
Dodge Badge
4X4 Badge
Removable Tailgate w/Caliper Latches
Front Air Dam
Front Bumper Sight Shields
50 State Emissions
Federal Tier 2, Bin 8A Emissions
EVAP Control System
26 Gallon Fuel Tank
Auxiliary Transmission Oil Cooler
Speed Control
Heavy Duty Engine Cooling
Next Generation Engine Controller
Graphite Metallic Clear Coat
All Radio Equipped Vehicles
AM/FM CD 6-Disc Radio
Infinity Speakers
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
Power Rack and Pinion Steering
Leather Wrapped Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Tilt Steering Column
Full Size Spare Tire
Tire Carrier Winch
P275/60R20 BSW All Season Tires
Goodyear Brand Tires
20" Steel Spare Wheel
All Aluminum Wheels
Center Hub
20X9.0 Aluminum Chrome Clad Wheels
Power Adjustable Pedals
Pickup Box
Class IV Receiver Hitch
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
Front Hood Protection Shield
Without Billable Fuel
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Four Wheel Drive (4WD)/(4X4)
6 1/2 FT. Cargo Box
Quad Cab
1500 GVW
Old May 19, 2009 | 09:19 PM
Twink's Avatar
Twink
just leave it. Not worth it to fix, its a truck. Beat on it till it dies.
Old May 19, 2009 | 09:25 PM
SilverBullet08's Avatar
SilverBullet08
7k...
Old May 19, 2009 | 09:40 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Trade would be a lot lower...if you want anything decent for it selling it is the only way to go. Might take awhile in this economy though. With the dents and high miles for a 04 i'd say around 6k trade and 9k sell if you're lucky.
Old May 19, 2009 | 10:28 PM
MontanaRAM's Avatar
MontanaRAM
you bought it with the dent and over 100k miles for 11k? sounds like you were had.
Old May 20, 2009 | 01:49 AM
dirtydog's Avatar
dirtydog
Moderate User
^^^^ Yup. That's not a dent. That's a sideswipe or entire side damage. i wouldn't have paid more than $7k like that with those miles. Sounds like $11k is what the guy owed on it.
If the street value is booked at let's say??? $11k. if the damage is $2k, you'll need to deduct that from the $11k and then prob another $500 because of the damage "dirty title" if you will.
Sad to say, but that truck if it's worth $8k you'd be lucky to get it.
Old May 20, 2009 | 07:58 AM
Off_Road_Teacher's Avatar
Off_Road_Teacher
With that size dent and that number of miles on a 4.7, I would say that in this area you would be lucky to get 7K for it.
Old May 20, 2009 | 09:27 AM
RubberFrog's Avatar
RubberFrog
2 bucks
Old May 20, 2009 | 04:37 PM
sabedra211's Avatar
sabedra211
oh wow lol. so around 7K ... How would i check if the title is clean? i did a carfax on it and there were no accidents reported on it. thanks 4 the replies every1!
Old May 20, 2009 | 05:40 PM
AK Rover's Avatar
AK Rover
I'll give you $10 for the truck with the dent.
