O2 sensor??
Old May 20, 2009 | 09:52 PM
SMKNRAM's Avatar
SMKNRAM
Default O2 sensor??
on 02 5.9 if i put true duals with high flow cats, do i have to have 2 O2 sensors? i will have an x pipe thought about putting one sensor in the middle of the x. anybody done this?
Old May 22, 2009 | 09:11 AM
SMKNRAM's Avatar
SMKNRAM
anybody with true duals on newer truck?
Old May 22, 2009 | 04:50 PM
Alpheus's Avatar
Alpheus
The upstream O2 sensor is the most important and its input is the info that the ECM uses for adjusting A/F ratios for best burn and to lessen emissions. The downstream O2 sensor is just for monitoring and its info is not used in any adjustments. I do not see any reason that it could not be used the the X pipe. There is a link for a mod that uses a spark plug anti fouling device to move the O2 sensor out of the high flow stream of exhaust to prevent a CEL from appearing. Its in the FAQ section. ..
