A/C vibrations
Old May 20, 2009 | 11:45 PM
jonnymagnum's Avatar
jonnymagnum
Default A/C vibrations
when ever I turn on my A/C it will vibrate pretty good and you can feel it in the cab of the truck. and it makes a low pitch humming noise.... I hope the pump aint going...... does anyone else have this problem?
Old May 20, 2009 | 11:52 PM
stereoking15's Avatar
stereoking15
sounds like a pump, usually if you add some compressor oil it will quiet down, pick up some at a napa or carquest in a can form usually made by johnsons or interdynamics, and then use a r134a can adapter with a shutoff valve and add about half can to see if it helps.
Old May 21, 2009 | 12:19 AM
jagass's Avatar
jagass
Maybe it's the pump...
