Old Aug 10, 2015, 02:57 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
need help quick..hid install
Old May 21, 2009 | 06:50 PM
02Steve1990's Avatar
02Steve1990
Default need help quick..hid install
hey guys i am installing hids right now and have taken out the stock headlights now there are two light bulbs hanging with wiring and i need to replace the high beam light with the hid bulb and ballasts..how do i get rid of this high beam light so i can successfully put the hid light in?
thanks
Old May 21, 2009 | 07:05 PM
RaiderJay6's Avatar
RaiderJay6
You should have only one bulb with the HID's.
Old May 21, 2009 | 07:09 PM
02Steve1990
i do only have on bulb for the hid's but there are two of the stock lights (turn signal and high beam) that are still connected to the truck and i need to replace the high beam bulb with the hid bulb
Old May 21, 2009 | 07:49 PM
RaiderJay6's Avatar
RaiderJay6
Take the headlight bulb out and replace it with the HID bulb.
Old May 21, 2009 | 07:56 PM
02Steve1990
ok we did that and we figured out how to connect most of the wires..the only thing we don't know how to do is connect a black and red wire coming out of the back of the headlight from the halos..where do we tie these up to? is black a ground, if so where does the red go?
Old May 21, 2009 | 10:29 PM
02Steve1990
...bump
Old May 21, 2009 | 11:21 PM
mmstar23's Avatar
mmstar23
you have aftermarket housing with LEDs and Halos or what?
Old May 22, 2009 | 06:42 AM
02Steve1990
stock housing with angel eyes kit in them..still stumped on that question..there are two wires coming out of the halos in the back of the headlight..i know the black is ground but where does the red wire go?
Old May 22, 2009 | 07:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well if those are two wires from the halos like you say and you know black is ground, what other wire do you have (red) that will supply power to them and turn them on?
Old May 22, 2009 | 07:24 AM
02Steve1990
i know the red is the power wire i just don't know where to connect it to, when the parking lights go on i want the halos to light up to (i don't know if that helps determine where to put the wire) but there are three wires coming out of each parking light bulb, do i need to strip a specific wire and connect the red to one wire?
