so fresh and so clean! motor = steam cleaned
Old May 22, 2009 | 03:45 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
Default so fresh and so clean! motor = steam cleaned
Old May 22, 2009 | 07:55 PM
Twink's Avatar
Twink
go short ram intake IMO.
i ran the short ram over the CAI for a while exact same intake and the short ram had a higher increase in power. The engine cpmnt doesnt get that hot with the v6 TONS of air circulatiing in there..
just my 2 cents..
besides that
looks like u slaved good!
Old May 22, 2009 | 08:01 PM
derricksmash
V6 Ram Moderator
it would look cooler...lol
maybe i will
Old May 22, 2009 | 08:13 PM
Twink's Avatar
Twink
use the the front peice, so your going to have to cut another hole from ur air temp sensor, make it short as possible and i gaurentee better throttle response and low end power. It loses a bit on the high end but i only noticed after about 100 mph
Old May 25, 2009 | 12:31 AM
MarkMark6464's Avatar
MarkMark6464
Dude, how'd you get her so clean?
Old May 26, 2009 | 12:17 AM
derricksmash
V6 Ram Moderator
blast your water heater in basement for a few hours...hook hose up to it...drag it outside...spray at engine. u don't even need to blast it...just literally SPRAY it, the mist/steam does EVERYTHING for you. then you just wipe once u run out of hot water. the nozzle on the hose gets so damn hot, you need to wear gloves and crap. it ridiculous how hot yoru water heater can get water if you BLAST it.
Old May 26, 2009 | 08:54 PM
sunneh63031's Avatar
sunneh63031
lool iv done that it kicks my pilot light out >.<
