Front Differential model number
Old May 23, 2009 | 09:42 AM
waltmoe's Avatar
waltmoe
Default Front Differential model number
I own a 2007 RAM 3500 5.9, auto transmission 4x4. How do I figure the model number of the front differential? I am changing the differential oil and need to get the front differential cover torque specs. Does anyone know if the front differential gasket is reusable?
Old May 23, 2009 | 09:57 AM
Alpheus's Avatar
Alpheus
Look on your glove box lid for your axle and diff info. The gasket is not reusable, its sealed with a high temp RTV silicone and the axle specs for my 2500 gasser are:
Bolt, Differential Cover 30 ft. lbs
Fill Hole Plug 25 ft. lbs
The fluid capacities are: 2.37 quarts for the front and 2.65 quarts for 10 1/2 inch, 3.81 quarts for a 11 1/2 inch rear axle...
Old May 23, 2009 | 12:06 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
you can also get the model number by getting under the truck. somewhere on that axle there will be a bright colored sticker with the model number. i think it will likely be closer to one wheel, wrapped around the axle tube.
Old May 23, 2009 | 01:23 PM
dodgediesel2500's Avatar
dodgediesel2500
The gasket is a reuseable rubber gasket, so don't throw it away. Your front axle is an AAM 9.25". The specs on your AAM 9.25" axle are as follows:
Front axle 9 1/4 AAM 74 oz = 2.31 qt 75W-90 or 75W-110 API GL-5 diff COVER BOLTS 30 ft-lb
Rear axle AAM 11.5 takes 122 oz. = 3.81 qt 75W-90 or 75W-110 API GL-5 diff COVER BOLTS 30 ft-lb
03-003-06 TSB for axle fluid fill level
rear pinion nut is a 36mm 12 point
front pinion nut is a 32mm
