04 4.7L ram 1500 rough idle problem
Old May 23, 2009 | 09:03 PM
Jobo04ram's Avatar
Jobo04ram
Default 04 4.7L ram 1500 rough idle problem
Ok so i have a 2004 ram 1500 4.7L with 63K miles on it. back in the winter it began to run rough when i first turned it on and the idle would settle after a minute or two. Now its summer and the idle is becoming even rougher in warm weather and takes longer to settle than before. Theres no stalling or problems idling after driving but i can tell that its getting worse with each trip i make, i did a search on the forum and im guessing the fuel pump is going bad?? help please, i need to take a cross country trip next week!
Old May 23, 2009 | 09:08 PM
HammerZ71's Avatar
HammerZ71
Possibly, but there are a lot of things can cause a rough idle. Dirty throttle body, clogged EGR, small evaporator leak could also be your problem. I'd start with the TB, because even if it's not your cause, it never hurts to do it and you'll gain performance.
Old May 23, 2009 | 09:18 PM
dazed01's Avatar
dazed01
ever done a tune up on it? Ever changed the plugs?
Old May 23, 2009 | 09:20 PM
dazed01's Avatar
dazed01
The egr stuck open a little would do that. Probably wouldn't be a bad idea to change it anyway since they seem to go out about that time anyway.
Old May 23, 2009 | 10:53 PM
Jobo04ram's Avatar
Jobo04ram
i forgot to add i had a tune up done about 3 months prior to the starting of the rough idle, TB was cleaned out and the plugs replaced and all that. it seems to get worse with each trip but never stalls or gives me problems other than the startup...
Old May 25, 2009 | 06:33 PM
ringnalda506's Avatar
ringnalda506
dear HammerZ71
I,m having simular problems with the idle rpm.(just not allways)
Can you explain how to clean the throttle body and what parts of the TB to pay special attention to. materials to use etc?
Thanks
Old May 25, 2009 | 11:25 PM
tafet's Avatar
tafet
Originally Posted by ringnalda506
dear HammerZ71
Thanks
https://dodgeforum.com/forum/3rd-gen...y-hemivec.html
Here is a link to the fac's section. This procedure should work whether your running a 5.7 or 4.7. The procedure is pretty basic and it won't take long to pull the throttlebody. Check out the Fac's section there is a lot of good info and DIT topics covered.
