Front End Noise Under Braking
Old May 28, 2009 | 12:31 AM
Decion's Avatar
Decion
Default Front End Noise Under Braking
Hi,
I have a '04 1500 quad cab 4x4. I replaced the brakes this past November. Recently I have noticed a noise that occurs under certain situations during braking coming from, I think, the driver side front. It only seems to occur in close proximity to a time that I have backed the truck up. It also seems to make a similar noise when backing up and braking. Anyone have any ideas what could be causing the problem? Could it be a slip in the brake pads that set after the first hard stop forward or backward? The sound is a metal on metal type of sound as opposed to a squeak. Any help appreciated.
Old May 28, 2009 | 03:49 AM
Alpheus's Avatar
Alpheus
You gotta rip it apart and look for worn or damaged parts. If you know the noise is coming from the front when you hit the brakes. You basically narrowed it down yourself. It could be anything...
Old May 28, 2009 | 04:09 PM
sos's Avatar
sos
I agree, you're going to have to take things apart and check them out. You should notice shiny spots wherever you have metal on metal movement. I think some of the more obvious spots would be the pad to caliper or movement in the caliper itself. The fact that you get it after changing direction sounds to me like you are on the right trail. Did you put any anti-squeal shims in there? They go between the caliper and the pad and prevent any movement between the two from causing squealing.
Old May 28, 2009 | 05:00 PM
Decion's Avatar
Decion
I did not put any new shims in, just the clips that came stock. I did add the anti-squeak lubricant that you put on with brakes. My thought is that the new pads are a touch smaller than they should be and it slips forward and back with the direction change. My ulterior motive for posting was to see if there was another reason that is common to the truck. Looks more like it is a unique problem to my vehicle. After my initial inspection I did not notice any problems. Like I said, it will happen at the end of my street when I leave home and I can drive all day, start/stop, as long as I do not back up the sound will not happen again. Unfortunately I do not think I can replicate the force of braking the vehicle on the jack stand to find the problem. I am getting new tires and alignment soon, I think i'll see if the garage sees any problems.
Old May 28, 2009 | 06:07 PM
Alpheus's Avatar
Alpheus
I would get it fixed ASAP. Brake malfunctions are nothing to put off until later. You don't want anything bad to happen to you or a family member because you put off a known problem. Excessive wear, heat and brakes is a bad combination. Safety first...
