pics of bubbling glass....
Old Jun 3, 2009 | 09:02 PM
Romeosoldier03's Avatar
Romeosoldier03
glass definately...cuz i got my window retinted thinking it was the tint....well...the tint guy showed me before he put the new tint back on....and sure nuff....it's the glass...that just pisses me off.
Old Jun 3, 2009 | 10:29 PM
cjs4444's Avatar
cjs4444
Yeah man this happened on my tahoe on both side of the windshield. I was told its the glue separating from the glass, Its not going to affect anything it just looks like crap....
ok just looked at your pic again and realized it was the door, and that makes absolutely no sense....weird...good luck bro.
Old Jun 3, 2009 | 11:03 PM
Hoss356's Avatar
Hoss356
Door glass isn't laminated, it's tempered. But that violates everything I know about tempered glass, because tempering is a heat treatment that leaves the glass with a hard outer shell and a liquid core, it doesn't make any sense that air could get in there and have the glass still be intact, your window should be "popcorned" in a thousand little pieces right now.
Old Jun 3, 2009 | 11:06 PM
Got_Hemi44's Avatar
Got_Hemi44
I would have said the window tint. You didn't clean your windows recently with anything besides water did you?
Old Jun 4, 2009 | 05:16 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
But I thought only the front glass had the plastic in it which is why it doesnt break or shatter like side and back windows?
Old Jun 4, 2009 | 07:50 AM
Nipplopolus's Avatar
Nipplopolus
MOPAR uses a "double glazing" (laminated) on the side windows for noise reduction.
Side windows are normally standard tempered (single layer) glass, but not in this case.
The problem is that water can get into the raw edge of the glass and begins to cause the plastic inter layer to discolor (white) and to delaminate. (usually extending about 2-3mm.)
Windshields do not usually show this delamination/discoloration problem to the same extent as the side windows because they are usually bonded to the aperture for strength thus preventing water ingress/damage.
Contact your insurance company. They may replace your window for you. Most cover windshield damage, who knows you may get lucky.
Old Jun 4, 2009 | 01:48 PM
Hoss356's Avatar
Hoss356
That's pretty interesting, what are some references so I can read more about this.
Old Jun 4, 2009 | 06:11 PM
Romeosoldier03
update....this is a growing problem with 06 and up dodge's....06 was the first year they started laminating these windows to be more like a windshield...during a crash it will help keep u inside the truck vs shattering and letting u fly out.....anyways...130 installed for new glass.
Old Jun 4, 2009 | 06:39 PM
02Steve1990's Avatar
02Steve1990
damn...i've never seen that before..weird
Old Jun 4, 2009 | 06:40 PM
MontanaRAM's Avatar
MontanaRAM
what a dumb thing for dodge to do, it's called buckle up and you ain't gonna go flying, DUH!
jeez, dodge should replace that for free since they screwed up IMO.
