HID Bi-xenon won't turn on???
Old Jun 9, 2009 | 07:45 PM
sweetsrt-10's Avatar
sweetsrt-10
Default HID Bi-xenon won't turn on???
I know some of you have installed these kits on your truck and can give me some help....I have the 4300K Bi-xenon (hi/lo) HID kit and I did everything right but no worky. Did some of you need resistor/relay or do you need both no matter what?
If you used resistor's can you tell me what kind or post pics of how it's set-up in your truck so I can get mine to work...
Thanks
Old Jun 9, 2009 | 08:19 PM
Matt99's Avatar
Matt99
The relays are the best fix. Easy to install and cheap. $10 for two.
will belancic's Avatar
will belancic
Can you give us more information as to how you installed the kit?
I am running a bi-xenon kit here in Canada but had to use a voltage stabilizer to over come the drl's issue of them flashing.
I also know that you can purchase a kit that takes care of the drl issue.
Let us know.
Old Jun 9, 2009 | 11:33 PM
sweetsrt-10
The issue I'm having is that my harness is making a clicking sound???? I thought I had a relay working out of my brothers truck but it doesn't work on mine. Basically my style relay is 5 prong bosch (only using 4 prongs) one positive connection one neg connection and then the high beam connection from vehicle harness is plugged in and white wire from HID kit is on the other prong.
