Gear Fluid Change
Ok, I've been all over the forums and cannot find exactly what I'm after...I know this from the manual and forums
Front Lube 75W90 Lube
Rear Lube 75W140 Lube (friction modifier required if not using synthetic w/ LSD)
I'm looking at the Royal Purple stuff..
Question is "how much of which?"
You'll need 3qts. for the rear You'll use 2.25qts+/- or 3.5pints as Chrysler states. Royal Purple states you don't need Additiives with their oils but i would add the 4oz required anyways.
Front will need 4.8pts or 2.4qts
